In-amp output signal clipped
fbp
Joined Aug 9, 2023
30
I am using the INA849 IC. My goal is to use 8V power rails, with a mid supply (4V) reference input to the in-amp. While simulating the circuit, my output waveform gets clipped.
Please guide me. Is there a particular connection I am not doing correctly?
fbp
Joined Aug 9, 2023
30
Do we have the give an offset of 4V to the input of the in-amp or directly give the input without an offset?
fbp
Joined Aug 9, 2023
30
The input signal is a 5Vpp signal with 500kHz. I am just not sure if a 4V offset is required at my input as well.
I am not able to access the link you shared in the previous message
fbp
Joined Aug 9, 2023
30
Sorry, I was able to view the image, it took time to load. I was wondering why a voltage divide at the input?
BobTPH
Joined Jun 5, 2013
11,659
You need to treat the mid voltage as your signal ground.
Connect the sine generator ground and the + input to the mid point voltage, not to the the battery negative.
BobTPH
Joined Jun 5, 2013
11,659
I have to set the input as mid supply as well?
Yes, it is the signal ground. If you connect an input to the battery negative, it is at -4V with respect to the reference voltage.
Think of the voltages this way: The midpoint is 0V, the supply positive is +4V and the supply negative is -4V.
fbp
Joined Aug 9, 2023
30
My input was actually already set to mid-supply. Am I doing something wrong in the connections or n the schematic?
