Hello everybody,
I'm developing an Inductive sensor, and I'm quite new in this field. I've found the best inductance values, coupled with capacitors to stay on the 500KHz frequency. I've chosen not shielded, ferrite core inductors, which seems to work better, I guess because they increase magnetic field.
I've chosen the target material to be Stainless Steel, which is optimal to achieve maximum distance.
Well, the problem is, that I want to reach a target which is at 5mm from my sensors, but actually I'm only sensing at 1.5mm. I'm thinking about increasing a lot the current, which is directly related to the magnetic field. But since this is a long life, battery powered application, I wanted to make sure that I'm doing everything right, before increasing the power consumption.
I also know that current is directly related to magnetic field, but magnetic field strenght decrease with distance with a square relation. To obtain the result that I want, I'd have to multiply current at least x8.
I'm buying random inductance to make some tests, because I could not found some "Sensing specific inductances". As long as you know, do they exist? Or they're all using common inductances?
Best Regards,
Davide.
Best Regards,
Davide.
