Implementation of a simple number counter for a mosquito zapper
dennipeter
Joined Oct 13, 2020
9
Hello folks,
I am a designer from India trying to make a mosquito zapper that keeps count of the number of mosquitos killed.
I am trying to implement a number counter to the circuit of a readily available mosquito zapper bat (Image below).
I want to do this using an arduino nano or an ESP 32 chip. Essentially, each time the zapper zaps a mosquito, I want it to send an input into one of the digital pins of the arduino.
The capacitor at the end of the circuit reads 2000v. I assume this is going to be the output voltage between the steel meshes. I do not have a high voltage multimeter to verify this. I am unsure about how to convert this into a safe voltage spike that can be read by the arduino's pins.
Apologies if this is a noob question.
AnalogKid
Joined Aug 1, 2013
12,278
Photo of the underside of the board. This will tell us if the magnetic component is a transformer or an inductor, and if either side of the 2 kV output is referenced to the input ground.
You probably can form a differentiator / edge detector / attenuator with a small, high-voltage rated capacitor and a resistor, plus a diode to keep the signal within the Arduino input voltage range. This should make a narrow spike pulse with each zap.
ak
dennipeter
Joined Oct 13, 2020
9
ak
Thanks @AnalogKid for the quick response.
Here are some more pictures of the mentioned part.
Could you point me in the direction of a similar example/ link / video explaining how to wire the mentioned differentiator circuit. The concept is new to me. I am not an electrical engineer by training.
jpanhalt
Joined Jan 18, 2008
11,087
Hello folks,
Obviously, you have never been to Minnesota. There, they keep score of the number of mosquitoes killed in a single zap. Your device might be useful in the antarctic.
Dodgydave
Joined Jun 22, 2012
11,395
Looks like the HV comes out of the transformer into a bridge rectifier using 4 diodes and a smoothing capacitor,into the Green and Red wires.
Is this fed from AC and DC voltage, as there are two bridge rectifiers ?
dennipeter
Joined Oct 13, 2020
9
Yes, you are right.
From what i have learnt. There is a cheap rechargable 3.3V battery inside. The transformer increases the voltage to about 300V, and then the capacitor increases that further to about 2000V.
I am not if the transformer, in the process converts to AC.
You mentioned that there are two bridge rectifiers with 4 diodes each? But I only see 3 diodes after the transformer.
sghioto
Joined Dec 31, 2017
8,751
I have never used one of these devices ,when a bug gets zapped does it make a loud pop?
If so wondering if a sound sensor might work.
dennipeter
Joined Oct 13, 2020
9
Yes,I did think of putting a sound sensor. But that did seem a bit rudimentary. Also, external sounds may be able to trigger the counter.
This thing works like a regular electric fly zapper, only change is in the form factor, and you can wave the bat around to hit the mosquitos.
sghioto
Joined Dec 31, 2017
8,751
I see three diodes and three capacitors. Might be a voltage tripler circuit but that would mean 800 volts off the transformer.
That might be your best option as far as isolating the bat from the arduino. Another idea is a sensor that will detect a "vibration" of sorts when the bug gets fried. Maybe a piezo sensor.
dennipeter
Joined Oct 13, 2020
9
Thanks you. Appreciate the input.
Is there not any other way to make a parallel circuit that can detect a large voltage spike in a nearby circuit?
I'm still waiting on a reply from @AnalogKid. But what do you think about his suggestion in post #2?
sghioto
Joined Dec 31, 2017
8,751
I would like to see that circuit as well.
Without a bat on hand it's difficult to know how the high voltage output changes when a bug is hit. I would think there would be a measurable drop and that would be useful. Either way using sensors or voltage differentials you are going to have to do some experimenting on the device to get the needed data.
Personally I think the piezo sensor idea is worth a look.
dennipeter
Joined Oct 13, 2020
9
Thanks, Didnt think of a piezo electric sensor. Can try experimenting with that.
