I'm new and need some help with cd4026b
rmitch
Joined May 24, 2008
24
I don't understand what I'm seeing on the datasheet for cd4026b. I have 5 volt power supply and I want operate a seven segment display. My questions are, what is rated current on the outputs to the display, and what is the rated current for the inputs? I been finding mixed answers from 1ma to 25ma on the outputs. The data sheet is confusing me. I'm new and learning on my own.
I'm figuring 10ma on the inputs and 25ma on the outputs. I have nothing to backup my decision
Papabravo
Joined Feb 24, 2006
22,101
In short, a Series 4000 CMOS device does not have the capability to drive an LED segment except at a very dim level of brightness with a Vcc of +5VDC.
rmitch
Joined May 24, 2008
24
hi rmitch,
Welcome to AAC.
This is a clip from the CD4026 datasheet, look at the 5V supply ratings.
E
If I understand correctly with 5v power, I will get 4.6 volts out, up to 1ma? Is this correct? Why does it show minus before the current values? And why does it show an output of 2.5 volts with a 5v supply? These are what confused me.
rmitch
Joined May 24, 2008
24
Thank you. In my readings a dim display is something I was going to expect. Hope it will be fine for testing for now
. Probably will have to use transistors for the final product.
ericgibbs
Joined Jan 29, 2010
21,522
hi,
The minus sign indicates that the current is flowing out of the 4026 pin, ie: it is Sourcing current.
Where is it showing 2.5V with a 5V supply means that will be the output voltage when the current is at that specified current, the current pulls the output voltage down.
E
E
rmitch
Joined May 24, 2008
24
hi,
E
E
Ok I see! That makes more sense now. So... If I'm pulling 1ma of current that will bring the voltage down to 4.6 volts. One more question... That's total output current? So I need to divide the current by how many output pins I'm using?
ericgibbs
Joined Jan 29, 2010
21,522
hi,
Thats the current for each output pin.
Normally that current is used to drive transistor so that a higher current can be created.
E
rmitch
Joined May 24, 2008
24
I have a 4026 driver that outputs v+ to the segments of a cc 7 segment display. There isn't enough power do drive the display bright enough through the 4026. My thoughts were to use a transistor as a switch, power the base with the v+ output of the 4026, and switch on the proper current to each segment individually. My thoughts were to use a npn transistor for this, but circuits show an npn should go on the - side of the load, not the + side where I planned to put it. I tried this on a breadboard and it seems to work fine, but I end up with voltage going in the emitter and out the collector to the display. I just don't know if it is ok to do so this way. Circuits show a PNP should go on the + side with the base activated with 0v. It's not the way the 4026 driver works. Im new and sure I'm missing a lot.
djsfantasi
Joined Apr 11, 2010
9,237
  1. Use a couple of CD4069s between the outputs of the 4026 and the base of the PNP transistor. Tie unused inverter inputs to ground on the 4069. Pretty straightforward.
  2. Use NPN transistors (with appropriate resistors. A 4K pullup and a base resistor). Connect the base to the 4026 output (through the NPN base resistor), the emitter to ground and the collector to the base of the PNP (at the junction of the pullup and PNP base resistors),
rmitch
Joined May 24, 2008
24
rmitch
Joined May 24, 2008
24
I meant to post #10 on the main forum.
Can it be moved?
MOD: Not sure what your asking.?
E
rmitch
Joined May 24, 2008
24
Can it be moved?
MOD: As the Threads where covering the same Topic ie: CD4026, the two Threads have been Merged.
rmitch
Joined May 24, 2008
24
I wanted to start a new thread on the main forum with post # 10. My questons were resolved with my original post. Now I have a new series of questions that's all. I'm sorry.
MOD: I would recommend that you keep these threads merged, the people helping on the original Thread will be possibly following you.
rmitch
Joined May 24, 2008
24
Not as simple as moving my current limiting resistor to the + side of the transistor and display on - side is it....
Questions... Does the 4069 inverter do just that? Invert my + signal to - signal? Then I use the transistors to switch on/off in the correct spot of the circuit?
ericgibbs
Joined Jan 29, 2010
21,522
hi,
If you use an inverting IC, it will need to be inverted again, say using a low power transistor.
I see from the earlier posts you are using a 5V supply.
You could use a CD4069 or a HEF4049 inverter, with output connected to a transistor driver.
Do you know how to do that.?
E
EDIT:
This clip from the CD4026 datasheet shows a low cost option.
rmitch
Joined May 24, 2008
24
hi rm,
What current level do you want for each LED segment.?
E[/QUOTE
Datasheet says 25ma continuous. So that's what I'm shooting for.
hi,
E
EDIT:
Oh, boy. I think I'm getting over my head here with this 4026 thing. I seen the use of the 4026 in the picaxe manual, looked simple to do but not so. In short, what I'm displaying is number of button pushes. Im looking at other options that I have that may be better. I have 74192 counters, 7447 drivers that can sink 24ma, and ca displays that look like might be simpler options to use. What do you think?
ericgibbs
Joined Jan 29, 2010
21,522
hi,
If you have a sketch of your final circuit idea to post, it would be helpful.
How many buttons etc..
E
This is another option.
Are the 7seg LEDs common Anode or Cathode?
