Identifying small, glass diodes?
skeer
Joined Oct 28, 2022
134
Looking for advice on how to correctly identify those tiny, glass, red/black diodes. Like these:
I have a couple small projects where I need a zener, I have several suspects but with no visible identifying marks I'm not sure if they are Zener or regular. (the first pic has ID marks.. ignore that the image is for physical reference only)
Advice?
panic mode
Joined Oct 10, 2011
5,307
... and if it is a zener, just measure breakdown voltage.
all you need is resistor such as 10k, DMM and power supply (30V should do just fine).
skeer
Joined Oct 28, 2022
134
Ah ok so just applying an increasing amount of voltage until it begins passing that voltage, yeah?
35,245
When forward biased, a zener looks like a regular diode.
You need to reverse bias the diode to determine the zener voltage. Use a series resistor to limit the test current.
panic mode
Joined Oct 10, 2011
5,307
for zener it is very simple,
supply voltage does not need to be adjustable, it can be fixed. you can use lower voltage like 12V but then you will only be able t otest zeners for less than 12V. so pick something high enough... 24V, 30V, 32V or so, and you can check 99% of zeners that you will come across
dl324
Joined Mar 30, 2015
18,478
Axial diodes should have sufficient space for identifying markings. Post some well-focused close-ups of the diodes in question.
I've sorted through thousands of loose diodes from the likes of Electronics Goldmine and have not come across any that weren't marked.
If they really don't have markings, you can reverse bias until they breakdown.
skeer
Joined Oct 28, 2022
134
Thanks guys, here's two of them. Both were removed from old EDR Electronic S100 motor control boards. I did contact EDR last year but could not get component details.. nor a schematic.IMG_0353.jpegIMG_0354.jpeg
schmitt trigger
Joined Jul 12, 2010
2,260
Are you sure they're diodes? Have never seen any that didn't have the cathode marked.
I have some chip caps in axial packages that don't have any markings...
If they don’t have the cathode markings, they could be DIACs or similar trigger diodes. If the motor board had a Triac to regulate speed, then those are DIACs.
Ya’akov
Joined Jan 27, 2019
10,330
Invest a few bucks into one of the ubiquitous “component testers“ available from your favorite source of those sorts of things. My recommendation is this one (photo) or a variant, which is marketed under various brands—this one is a Longrunner. You can get them from Hiletgo on Amazon as well.
skeer
Joined Oct 28, 2022
134
I did not see this response until just now however I did actually order one of those. $14 for the one without a case..
Ian0
Joined Aug 7, 2020
13,297
Thanks guys, here's two of them. Both were removed from old EDR Electronic S100 motor control boards. I did contact EDR last year but could not get component details.. nor a schematic.View attachment 325387View attachment 325388
That will be a diac.
It will break over at about 32V in either direction, so as you increase the voltage to 32V when it gets to 32V it will suddenly start to draw current and the voltage across it will go to about 0.8V
