2SK39A N J-FETi have a sony stereo electret condenser from the 70s. one of the transistors has failed but i cannot identify the transistor. can anyone help?
the code reads K39A CI2
View attachment 305517View attachment 305518View attachment 305519
the microphone is an ecm 99 if that helps.
Thanks, do you know where I can buy one of those or the modern equivalent?2SK39A N J-FET
No, I don't unfortunately. Have a look at the following website topic which might give you some ideas:Thanks, do you know where I can buy one of those or the modern equivalent?
There they mention pulling the jfets out of electret capsules, do you know if that's reffering to the small ones you can buy for projects?No, I don't unfortunately. Have a look at the following website topic which might give you some ideas:
https://www.eevblog.com/forum/projects/jfet-for-electret-mic-follower/
Good luck.
I found this cross reference:do you know where I can buy one of those or the modern equivalent?
