Hello everyone
My daughter owns a small consumer digital camera which has lost the ability to hold charge. So I pulled the camera apart in order to replace the battery since it's pretty much dead. The battery I found inside is the one you see on the photos attached. I hoped for ID information printed on it, but nothing there. Would anyone here possibly know how to trace down which one it is, and where to order a replacement?
The main dimensions are 50 mm x 30 mm x 5 mm. The connector is 3 mm across, and has a flange that is 5 mm across.
Thanks very much!
Thanks very much!
