Ideas for command protocol
spinnaker
Joined Oct 29, 2009
7,830
Thanks for the suggestions. Below is the code that I went with. Nice and simple. I think CRC check would be overkill since it is rare I will be setting the time and date.
I still need to add more error checking to make sure the strings are assembled correctly. Right now I am forced to set the time as HH:MM:SS and the date as MM/DD/YY.
Code:
  if (PIR1bits.RC1IF)
  unsigned c = uart_getChar();
  if (c == '\r' || c == ';')
  processCmd(cmdBuffer);
  memset(cmdBuffer,0,strlen(cmdBuffer));
  cmdBufferNdx = 0;
  else
  cmdBuffer[cmdBufferNdx] = c;
  cmdBufferNdx++;
Code:
#include <string.h>
#include <stdio.h>
#include "processCmd.h"
#include "uart.h"
#include "picrtcc.h"
unsigned processCmdGetTime()
  char buffer[25];
  struct PICRTCC_date picRTCCDate;
  struct PICRTCC_time picRTCCTime;
  PICRTCC_readDateTime(&picRTCCDate,&picRTCCTime);
  sprintf(buffer,"%c%c:%c%c:%c%c",picRTCCTime.hour.BCDparts.HRTEN+48,picRTCCTime.hour.BCDparts.HRONE+48,picRTCCTime.minute.BCDparts.MINTEN+48,picRTCCTime.minute.BCDparts.MINONE+48,picRTCCTime.second.BCDparts.SECTEN+48,picRTCCTime.second.BCDparts.SECONE+48);
  return PROCESS_CMD_SUCCESS;
unsigned processCmdGetDate()
  char buffer[25];
  sprintf(buffer,"%c%c/%c%c/%c%c",picRTCCDate.day.BCDparts.DAYTEN+48,picRTCCDate.day.BCDparts.DAYONE,picRTCCDate.month.BCDparts.MTHTEN+48,picRTCCDate.month.BCDparts.MTHONE+48,picRTCCDate.year.BCDparts.YRTEN+48,picRTCCDate.year.BCDparts.YRTEN+48);
unsigned char processCmdGet(char * buffer)
  switch(buffer[0])
  case 'T':
  case 't':
  return processCmdGetTime();
  case 'D':
  case 'd':
  return processCmdGetDate();
  return PROCESS_CMD_INVALID_GET;
unsigned char processCmdSetDate(char *buffer)
  char *token;
  char params[4][10];
  char delimter[2] = "/";
  unsigned char  i=0;
  token = strtok(buffer,delimter);
  while (token != NULL)
  strcpy(params[i],token);
  i++;
  token = strtok(NULL, delimter);
  PICRTCC_setMonth(params[0][0], params[0][1]);
  PICRTCC_setDay(params[1][0], params[1][1]);
  PICRTCC_setYear(params[2][0], params[2][1]);
unsigned char processCmdSetTime(char *buffer)
  char *token;
  char params[4][10];
  char delimter[2] = ":";
  unsigned char  i=0;
  i++;
  PICRTCC_setHour(params[0][0]-48, params[0][1]-48);
  PICRTCC_setMinutes(params[1][0]-48, params[1][1]-48);
  PICRTCC_setSeconds(params[2][0]-48, params[2][1]-48);
unsigned char processCmdSet(char *buffer)
  switch(buffer[0])
  case 'T':
  case 't':
  return processCmdSetTime(&buffer[1]);
  case 'D':
  case 'd':
  processCmdSetDate(&buffer[1]);
  return PROCESS_CMD_INVALID_SET;
unsigned char  processCmd(char *buffer)
  switch(buffer[0])
  case 'G':
  case 'g':
  return processCmdGet(&buffer[1]);
  case 'S':
  case 's':
  return processCmdSet(&buffer[1]);
  return PROCESS_CMD_INVALID_CMD;
djsfantasi
Joined Apr 11, 2010
9,237
