Ideas for Arbitrary Waveform Generator, 100V.
Jimmytr
Joined May 15, 2015
4
I am trying to build an electrical stimulator (not for being used in living things) for a biomedical project, some of the parameters to control are waveform (pulse,triangular), voltage around 100v, waveform period (500 us-250ms) and frequency (1Hz-30Hz)
The approach i´m trying is to use a "high voltage" PWM signal + RC filtering. Now i realize that obtaining a "high voltage" PWM signal is not that easy, even though i´m using a pulse transformer.
To avoid DC bias in the pulse transformer i tried this:
Every stage goes as planned until the rectifer bridge before the RC filtering. I think that maybe there is
a more elegant approach for the task, so i would like to know and suggestions/ideas on the project.
I really appreciate any help you can provide.
pwdixon
Joined Oct 11, 2012
488
What's wrong with using a boost regulator to generate 100Vdc and then just using a high voltage FET to switch the output to the filter? Are you trying to generate just a voltage at low current or at some high current level?
Hypatia's Protege
Joined Mar 1, 2015
3,228
Inasmuch as 'biomedical' translates nicely to 'life+health', your assertion that the project is not for application to organisms is a tad incongruous -- IOW, while I hesitate to suggest that the original post is 'oxymoronic', the fact remains...;) --- Thus it seems that, dependent upon the organism{s} involved, "VI AAC III" may prohibit substantive response to your inquiry -- Elucidation, however, may improve my perspective...
With marked jocularity
HP:D
Jimmytr
Joined May 15, 2015
4
HP:D
Yes you are right, the post is somewhat 'oxymoronic', but that was not the intention.
I'm a biomedical engineer student, and this project is just for learning purposes.
The idea of using a transformer came from the university professor, working with the project
i realized that maybe there was a more elegant solution. I just wanted ideas, suggestions to make a
better project and to learn different approaches so maybe one day i'll be able to build a real one.
12,175
A pulse transformer is better at delivering things with a rectangular pulse shape than other transformers, but don't think that its output will have nice square corners, like a clock source only bigger. As suggested, a better way is a 100 VDC source powering a linear wideband amplifier with pulse, triangle, whatever as its input. You'll have much better control over the output amplitude and load impedance matching.
Jimmytr
Joined May 15, 2015
4
Low current, max. 40-50 mA throug a ~220 Ohms load.
I search for dc-dc converters and found R24-100B. As for the FET , is there any particular suggestions?.
(I have mainly worked with BJT transitors so i don't claim to be an expert).
