I got two oscilloscopes which has got the plastic rod which connects to the "on" button snapped off. The button is also plastic. Now to put it back together I was thinking of using something like epoxy, which should be strong enough. But then I thought if the unit has to be serviced again it would be a nightmare to take it apart.
I thought of using hot glue instead. Is that a good idea? Considering that the oscilloscopes get quite hot when its on, using another kind of glue would not work right? and also hot glue should be quite easy to remove when it comes to opening the unit.
Appreciate your advice and ideas
Thanks in advance.
Thanks in advance.
