IC Identification
thunderace7
Joined May 7, 2016
7
Hi, I am playing with some Christmas lights that stopped working because water got in to them. I have taken them apart to try to see how they work. They are a set of "Icicles" each of which has 18 leds in a row and they light in turn starting at the top and cascading to the bottom. They seem to be driven by a 6v DC source and each icicle is independent of the others i.e. it will work in isolation. There is an 8 pin surface mount chip that drives the leds and it is this I am trying to identify. It is labelled as 171009, with 72 below that. The PCB is marked U1 with 5072B. I can find no reference to any of these numbers.
I am interested in this chip because it seems to be able to drive 18 leds sequentially with only 4 control leads. Looking at the PCB, there are leds connected between the leads in a variety of combinations and polarities. I have tried to measure waveforms with my PC Scope but the leds behave differently when I connect the leads and the readings do not make sense. I suspect that the scope has too low an input impedence.
Has anyone any idea as to what chip this is using?
Thanks.
SamR
Joined Mar 19, 2019
5,542
Most scope have ~1MΩ input impedence. Try putting a multi kΩ or MΩ resistor in series with your probe. Most likely it is a preprogrammed IC to control the lighting sequences.
