IC 741 amplifier circuit
Sensacell
Joined Jun 19, 2012
3,789
An opamp could be used to 'close the loop' around a secondary voltage amp with a 50 V output capability?
Of course with the feedback attenuated to meet the opamp voltage limitations?
Devil is in the details:
What kind of gain and offset accuracy is required?
What is the load?
What bandwidth?
vishal0312
Joined Dec 23, 2016
What is the load?
What bandwidth?
sorry it is 0 to 5 volts i don't want to operate any load on that and it is 0 to 20 milli volt DC signal which i have to amplify
AlbertHall
Joined Jun 4, 2014
12,663
Neither the input nor output can swing to the negative supply rail so you will need to use a split rail supply, say ±10V.
Then you can connect your input to the non-inverting input and set the gain to 5V/20mV, or 250. For instance, from the inverting input connect a 1k resistor to 0V and a 249k resistor to the output.
GopherT
Joined Nov 23, 2012
8,009
sorry it was a mistake i want to convert 0 to 5 volt from 0 to 20 milli volt DC signal
As said above, the 741 output cannot go all the way to the supply voltage. If you supply with -15 to +15 volts, it can only output a range of -14 to +14 (into a big value resistor like 10k and more). If you drop down the load to 1k or so, the output can only cover the range of -13 to +13. Worse as the load gets smaller - check the specs for max current.
NOTE! The input offset voltage is 1 - 5 mV or, in your case 5 to 20% error. You will need to trim the OP amp. See DATASHEET for instructions.
hp1729
Joined Nov 23, 2015
2,304
i want to amplify 0 -20 milliVolt (DC) to 0-50 volt using Opamp IC 741 can anyone help me with circuit design.
It can be done with power rails of +9 V and -9 V. The LM741 does not work well close to power rails. For a reliable +5 V out you need +V of about +9 V. With an input close to ground you need the negative power to be negative, not ground.
Or use a better op amp.
The LM741 is used in learning exercises because it has all the defects of a bad op amp. It is a good example of a bad example. :)
38,952
Yes, it's very good for teaching op amp frequency response limits, input and output voltage limits with respect to the power supply voltage, the effect of amplifier offsets, etc.
Truly a good bad-example. ;)
