IC 4017 output modification
ThePanMan
Joined Mar 13, 2020
953
The way it works is that there's always one out of 10 outputs active. If you want to start at output 1 but have it OFF when you start then use out-1 for the first LED. Out-0 will be the first output to go high when you power the circuit. If nothing is attached to "0" then the next clock will drive "1" high. That's where you have LED 1.
Have a look at post #5 again. You'll see Out-0 is not connected to anything.
eetech00
Joined Jun 8, 2013
4,751
Connect a 0.1u cap and pull down resistor to the 4017 reset pin like I show in my circuit post #9.
This ensures the counter will always be reset at power on (Q0 will always be high at power on).
