What did you fix exactly?
S sghioto Joined Dec 31, 2017 8,758 Jun 7, 2023 #22 In the dark detector circuit you have Vcc pin8 on U2 at 5 volts and the LDR components at 9 volts. Why? If the PIR will operate on 5 volts then I would suggest running both circuits on the 5 volt regulator.
