i want to merge this circuits into one, can someone help?
laby
Joined May 17, 2023
8
the circuit on the right is a darkness sensor while on the left is a motion detector using PIR. I want to combine these two circuits into one. The motion sensor must only function if the LDR detects darkness and it must not function if the LDR doesn't detect any darkness.
im making a school project, the circuit at the right is a darkness sensor using LDR and its steps and components are:
STEP 1 - Connect 555 timer IC on the breadboard
STEP 2 - Connect Pin 8 of 555 Timer to VCC of Battery
and Pin 1 of 555 Timer to GND of Battery
STEP 3 - Connect pin 4 to VCC and Connect pin 6 of 555 Timer to the pin 7 of 555 Timer
STEP 4 - Connect 330-ohm resistor to pin 7 and pin 8 of IC
STEP 5 - Connect 4.7uf polarized capacitor to pin 5 of IC and its negative side to the ground
STEP 6 - Connect 0.01uf ceramic capacitor to pin 6 of IC and its negative side to the ground
STEP 7 - Connect 4.7k ohm resistor on pin 2 of IC and its negative side to the ground
STEP 8 - Connect LDR to pin 2 and VCC
STEP 9 - Connect 470-ohm resistor to pin 3 of IC and connect its other side to the anode of the LED and its cathode to the ground
STEP 10 - Test if the circuit works
while the circuit on the left is a motion detector alarm using PIR (HC-SR501) and its steps and components are:
STEP 1 - Connect 555 timer IC on the breadboard and a 74HC04 IC
and Pin 1 of 555 Timer to GND of Battery. Also connect pin 14 of 74HC04 IC to VCC and pin 7 of 74HC04 IC to GND.
STEP 4 - Connect 100-kilo ohm resistor to pin 7 of 555 IC and its other side to the VCC
STEP 5 - Connect 4.7uf polarized capacitor to pin 7 of 555 IC and its negative side to the ground
STEP 6 - Connect 0.01uf ceramic capacitor to pin 5 of 555 IC and its negative side to the ground
STEP 7 - Connect a buzzer to pin 3 of 555 IC and its negative side to the ground
STEP 8 - Connect the pin 2 of 555 IC to pin 12 of 74HC04 IC
STEP 9 - Connect the GND of PIR to the ground, its power pin to the VCC and its Signal/output to the pin 13 of 74HC04 IC
do u have any suggestions on how we can merge the two circuit into one according to the said output?IMG_5225.png
sghioto
Joined Dec 31, 2017
8,756
Several things not correct.
The 9 step construction of the dark detector does not match the breadboard layout.
The .01 uf cap should be on pin5.
Don't need the 4.7uf cap or 330 ohm resistor.
Connect pin6 to pin2. No connection on pin7
This is all you need for a basic dark detector.
Additional components can be added to control the sensitivity and hysteresis.
sghioto
Joined Dec 31, 2017
8,756
The motion circuit looks OK.
To combine the 2 circuits connect pin4 of the motion detector circuit to pin3 of the dark detector. Do not connect pin4 of the motion to Vcc.
Ya’akov
Joined Jan 27, 2019
10,332
Welcome to AAC.
Your thread has been moved to the Homework Help forum. Because AAC rules limit the sort of assistance members can provide with coursework to guidance on moving forward with a student’s own ideas. Because of this, all such posts must be made to the Homework Help forum.
It’s good to have you with us, and good luck with your project.
panic mode
Joined Oct 10, 2011
5,336
yup, mentioned schematic was an abomination, no better than image of the bread board. circuits need to be drawn in a logical layout so one can follow the circuit function.
MrAl
Joined Jun 17, 2014
13,833
do u have any suggestions on how we can merge the two circuit into one according to the said output?View attachment 295492
The description you gave of the circuit looks like it came straight out of the mouth of an ai bot.
Is this true?
Also, who made your schematic?
laby
Joined May 17, 2023
8
what connection should i do with the 5V voltage regulator so that if i use a 9V battery my circuit will work? as you can see in the schematic and in the picture, only the left part of the circuit works when it detect darkness, the right circuit won't work especially when the pir sensor detects motion,the buzzer is not buzzing
