So are you saying like in the real world one of the transistors will go to saturation mode first and thus the other one will go to cutoff mode and that neither of them go to active mode?That state may be stable in the simulator, but it is not in the real world. It will flip to one transistor on (saturated) and the other off. It is called a bistable multivibrator because there are two stable states, neither of which has the transistors in the active region.
Yes, but more accurately, they will not stay in active mode.So are you saying like in the real world one of the transistors will go to saturation mode first and thus the other one will go to cutoff mode and that neither of them go to active mode?
My sim doesn't do that.When I simulate with LTSPICE, the original circuit flips to the stable state after 600 usec. I
Interesting that my sim of the same circuit with those transistors doesn't do that.Exactly what the TS posted, with 2N3904 transistors. 5V supply.
How so?Both transistors are in the active range because the resistor values are incorrect for the transistor types.
