I want one SEPIC CONVERTER schematic to boost my voltage
VINAYARUGI
Joined Aug 7, 2018
9
I want SEPIC CONVERTER schematic to boost my voltage from 12V supply. Iam using 5V PV panel and 12V battery supply as input to SEPIC.
Bordodynov
Joined May 20, 2015
3,433
Why do you need a SEPIC CONVERTER! You do not need to lower the tension! The boost converter has fewer details. Also, I doubt that you need such a small current. Which device are you going to connect to the converter? It also does not make sense to use an IGBT transistor. At low voltages you will get a low efficiency and will have to put a lot of effort (many additional details), because to control such a transistor 5 volts is small.
