I need help with transistor operated relay
*synonymous*
Joined Nov 29, 2013
35
Hello and thank you!
I am making a circuit that uses a dual polarity power supply and relay and would like some help if possible. What I need is for the relay to use both the positive and negative taps and for the coil to be switched on based on a ground switch connection. Please take a look at the attached prospective image and offer any advice or magic that you have.
Thanks
S
34,469
This is another way to look at it.
This might not be exactly what you need, but this is a conversation. You can tell us if this will not work for you.
I like that. :) It's simple and works since the off switch position is open circuit.
Unless there's some reason that both supplies have to be switched as the OP shows, but that seems unlikely.
#12
I think he gave us 2 options, not 2 requirements, and his drawing does show a switch that seems to go nowhere in one position. So, I took a stab at it.
Alec_t
Joined Sep 17, 2013
14,335
Are you saying that the coil must be connected between the + and - ; or that the relay contacts connect to the + and - ?
*synonymous*
Joined Nov 29, 2013
35
Hi and thank you to all the posts!
#4 looks great, I love using few parts.
Yes, it is the coil that is connected to the +12 and -12 but in this case, through the transistor. I suppose that I could have been a little clearer but it appears to have gotten the idea across. Yes also that the ground activates the circuit and that an open disables it. The main idea with this circuit is that I wish to load both rails equally using 24v relays and not use 12v overloading one or the other. I have another relay that will trigger this circuit that in one position grounds another device and when energized will ground this circuit into the on position. I will post that schematic when it grows closer to fruition.
I really appreciate the abundance and quickness in responses
Thanks again
Scott
*synonymous*
Joined Nov 29, 2013
35
Hello again and thank you!
Would in the following attachment change your circuit create a delay on? If I were seeking about a 1 second delay, what value capacitor would I use? I may be able to swap this circuit in to reduce yet another part in the design!
Thanks
Scott
#12
The capacitor for this circuit turns out to be about 2200 uf but there are better ways to do this. A time delay is not the same as a switch. If you want a time delay, it is much easier done with a mosfet or a jfet. Start another thread so the other denizens will consider it.
*synonymous*
Joined Nov 29, 2013
35
Thank you #12!
I think I know what you are saying. The BJT isn't exactly an on/off device in this case. Ok I will start a new thread!!
Thanks
Scott
