I need help with this transfer function.
dimatizer
Joined Dec 1, 2012
3
G(s)= (3RCS+(RCS)^2+1)/[(SC)^2)(RSC+2)^2]
I achieved this answer by doing VC2=I2/CS=(Inot/cs)(1/SRC+2) and
Vin=(Inot)(Z) were Z is the equivalent impedance and my Transfer function is Vc2/Vin
I need help figuring out what I'm doing wrong because I don't believe I'm getting the right answer
33,325
Without commenting (yet) one whether you are right or wrong, why is it that you believe you aren't getting the right answer? What have you done to check you answer?
dimatizer
Joined Dec 1, 2012
3
i found the transfer function of just the left circuit to be 1/(1+RCS) . i believe the right answer should be [(1/(1+RCS))(1/(1+RCS))]
blah2222
Joined May 3, 2010
582
Also, it would help if you used LaTeX formatting to read these equations easier.
http://en.wikibooks.org/wiki/LaTeX/Mathematics
G(s)\ =\ \frac{3RCS+(RCS)^{2}+1}{(SC)^{2}(RSC+2)^{2}}
Is a lot easier to read than:
Now, I have not verified if this is indeed correct but for the sake of making it easier to read. Click "quote" to see the formatting.
ramancini8
Joined Jul 18, 2012
473
Look to the left of the dotted line and calculate the Thevenin equivalent circuit. Replace the stuff to the left with the TEC, and use the voltage divider rule to calculate the voltage across C2.
