I need Help with one question on S\H
how the output waveform will see ?
  • sample and hold
    Votes: 0 0.0%
  • 1
    Votes: 0 0.0%
  • Total voters
ronald1980
Joined Oct 29, 2016
6
Explain the principle of operation. (S / H) a. Figure 4 question given circle principle of sample and hold Copy your notebook the waveforms in Figure A and sketched underneath the resulting output waveform
1. how the output waveform will see ?
thnkas,
bertus
Joined Apr 5, 2008
23,000
I think he means circuit in stead of circle.
@ronald1980 , Show us what you think the output signal looks like.
Then we can see if that is correct and give suggestions when it is wrong.
Bertus
MrAl
Joined Jun 17, 2014
13,788
thnkas,
ronald.View attachment 114416
You can probably consider the MOSFET low resistance when on and high when off.
You also have to consider what happens because of that capacitor and resistor on the output.
If you can show what you think might happen you may be right already :)
If you have no idea then you'll have to mention that too then.
