I need help to understand circuit
WBahn
Joined Mar 31, 2012
33,370
Look again, because I don't see "two pin[ s ] grounded".
Is this a language issue or have you misunderstood?
Since you could find the datasheet to attach, I can only hope you have read it.
I am starting to forget the question...
I don't think we've ever gotten far enough to even have a coherent question framed.
Round and round.
abhimanyu143
Joined Aug 25, 2014
211
Is this a language issue .
that was my mistake
you did connected two pin together because we just need both pin high or low.
When the signal is LOW, existing data is retained in
a hold (“do nothing”) mode.
when the select pin is HIGH, data is transferred to the Q0 to Q3 outputs respectively,
