MaxHeadRoom
- Joined Jul 18, 2013
- 30,806
Is that blue wire going to one side of both windings?
I dont see the supply across the run winding?
you mean this?In your original pic, you show B1 & B2 connected together, what is the reading from this strap to C1 & C2?
Oh, YES, I didnt touch those wiring. , but B2 and C1 was connected together externally with a wire,on the other motor as I discovered later.
I know, but im at that point I try everything, haha....You cannot use those capacitors to run a motor they will blow...
You are right, a circuit is better to have at this point to clarify what is what.Was this the original connections?
What are the actual resistances between each terminal?
All you are doing there is placing the cap across the supply, it does nothing for the motor!!I know, but im at that point I try everything, haha.
Here it is: (I even color coded every wire)
Like I said, I discovered there was a wire link externally, but was bend under the motor and I thought there were some cut wires as well, but when I dragged the wire more, surprise, was a link on B2 and C1 as shown and explained already.
