I need Bk Precision 4086AWG PCB photos
Nuljaska
Joined Oct 11, 2019
Hello everyone. Do anyone has photos of this generator PCB boards. I need photos so i can know where my off soldered components belongs. I need photos of these components spots: all of the little red resistors(total 9), all of the big capasitors(total 9), and all of the regulator type cased components on power board (total 11). I need photos where i can clearly see names of components and their spots.
Thanks.
28,244
You will have more success getting a circuit diagram and then tracing out the circuit on the PCB to find the locations. How do you have the instrument with a circuit board with all of the parts removed? That must be an interesting story.
Nuljaska
Joined Oct 11, 2019
I thought no one has schematics because i tried to find them from internet and even asked straight from Bk Precision, but i didnt get them. I found generator from trash can and it was broken. Then i soldered off some usefull components and after that realised that i could to fix it because generator is actually pretty expensive. But if anyone has schematics, i would really like to get them. Thanks.
SLK001
Joined Nov 29, 2011
1,549
That actually looks like a nice generator. Perhaps next time you will try to fix it BEFORE you start pulling off parts.
28,244
OK, now that makes sense. B&K is a good brand and possibly searching under the name B&K will work better. And there are sites like "schematicsforfree" that have a lot of information that does not always appear on general searches. And also, if the boards are marked so that you can know that the part was a resistor or capacitor or a semiconductor device, you can then trace out a circuit and get helpdiscovering the values. AND, if you still have those parts that were removed, note the values, and that can be quite helpful i discovering what values go where. But if it was indeed not working then at least one part may be deffective.
dl324
Joined Mar 30, 2015
18,464
Live and learn... Don't be so quick to salvage equipment for parts and take a picture before you start next time.
