I thought the ssr I posted was a optocoupler ssr . Well that's what I found from my research . The 90 - 250v should work right . As the pot on circuit 2 will reach the minimum 90 what's quite easily I would assume ,turning on the circuit 1 . Circuit one has an led driver that requires a constant 110v to 240v input and will out put 12v at 6 amps to the led strip . I will look into what you have said a little more and post back . Thank you for your reply you have been very helpful .
