And what does the AVR do ? ATS (Atomatic Transfer Switch) ?As the title say, I would like to know more info about the generators. The S STAR, 220V 3ph generators.
And it's AVR circuitry too.
Any one here has any in depth knowledge on them ?
I know the question is very vague and I did a lotta reading on it.That's a very large subject and can't be covered in a few paragraphs.
What exactly are you questions about them?
It's not clear to me exactly where this sparking is occurring.The issue is sparking across the exciter rotor diode set.
So my question still is, where exactly is this sparking occurring?There are no brushes.
I do not quite get youThere are several different configurations for exciter current. Do you have a print?
When the rectifier diode rotates, spark also flies around the diode.So my question still is, where exactly is this sparking occurring?![]()
While it won't be of much help the AVR is the automatic voltage regulator which should maintain the output voltage constant as the load changes. The ATS is as you mentioned, the automatic transfer switch. When a generator is used in an emergency backup capacity it has a routine similar to this. Mains power fails, including in 3 phase systems the loss of a phase. The generator will automatically start and come up to speed (frequency and voltage). At this point, normally around ten seconds the system will automatically transfer from mains source to generator source, generally using a set of large contactors mechanically interlocked.And what does the AVR do ? ATS (Atomatic Transfer Switch) ?
Just curious, Some Stanford generators have Varistors with the diodes for HV spike protection. Sparking suggests over voltage. What is the generators out put voltage when diodes are sparking?
It was an example. open circuit outputs/no loads are usually forbidden on alternators and generators because they tend to overvoltage, despite their regulators. will need to contact maker or installation engineer to find minimum load. There may be a default standard %age of output, but it's more likely machine dependent. NB It could be a large portion of the total output.Were not talking Car altenators. This is a 3 phase 240V AC generator, & the AVR is supposed to control the voltage.
Picture?When the rectifier diode rotates, spark also flies around the diode.
