I can't stop PWM signal. It always works.
ali ahmet
Joined Apr 30, 2019
Hi, i am new with MSP430.
I would like to create a PWM signal when button is pressed to transmit IR signal and stop it after 50 miliseconds. But i cannot stop it.
Here is my code
#include <msp430.h>
void startPWM(void);
unsigned char counter=0;
void stopPWM(void);
int main(void)
WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
BCSCTL1 = CALBC1_1MHZ; // Set range
DCOCTL = CALDCO_1MHZ;
CCTL0 = CCIE;
P2DIR |= BIT2; //IR transmitter
P2SEL |= BIT2;// Select pwm pin (transmitter)
P2OUT=0x00;
while(1){
if((P1IN & BIT4)!=BIT4) //button is pressed
startPWM(); //send pwm
stopPWM(); // stop after 50 ms
void startPWM(void) // pwm signal
TA1CCR0 = 26-1; // Period Register
TA1CCR1 = 13; // 50% dutycycle
TA1CCTL1 |= OUTMOD_6; // TA1CCR1, Reset/Set
TA1CTL = TASSEL_1 + MC_1 + TACLR;
void stopPWM(void) // trying to stop after 50 ms
CCR0 = 5000; // CCR0 5 ms
TACTL = TASSEL_2 + MC_2; //
#pragma vector=TIMER0_A0_VECTOR // Timer0_A0
__interrupt void Timer_A (void)
if(++counter==10){ // is counter 10 (5*10=ms)
TA1CCR1 = 0; ; // Stop timer so it can't send PWM signal
counter = 0;
BobaMosfet
Joined Jul 1, 2009
2,211
Use code formatting tags please, and flowchart your code- that will reveal any logic problems.
Cleaned up a little bit- Don't be lazy when it comes to formatting code, make it easy to read, and put semicolons where they go (syntax):
Code:
*  INCLUDES
#include <msp430.h>
*  PRAGMAS
*  GLOBALS
* GLOBAL PROTOTYPES
void stopPWM(void);
*  INTERRUPTS
__interrupt void Timer_A(void)
    if(++counter==10)
        TA1CCR1 = 0;                    // Stop timer so it can't send PWM signal
        counter = 0;
*  FUNCTIONS
*  MAIN
int main(void)
    CCTL0 = CCIE;
    P2SEL |= BIT2;                    // Select pwm pin (transmitter)
    P2OUT=0x00;
    while(1)
        if((P1IN & BIT4) != BIT4)            // button is pressed
Likely your counter is zero, because every time the interrupt exits, that variable is dumped off the stack frame. If you're going to keep a count in an interrupt, it has to be a volatile global variable.
