I can't get high frequency output of my Ramp Generator
Chandler Timm Doloriel
Joined Apr 5, 2018
54
I've been working about this ramp generator circuit (attached file) for my research. Initially I want to have a ramp output of frequency 100MHz to 1GHz but I have a problem because i can only get 20-30kHz ramp signal. In my reference paper, the formula of frequency is f =Vref/(RtCt(Vh-Vl)) or f = Io/CV, but no matter what value I change the parameters(Vref, Ct, Rt and Schmitt trigger sizes) it still would not get a high frequency output, instead the I only get a distorted one.
Here are the values of the parameters that I can get a clean ramp output but with small frequency:
Rt = 5k
Vref = 1V
Ct = 1nF
Vh = 0.7V
Vl = 0.25
using the formula f =Vref/(RtCt(Vh-Vl)); f = 444.44kHz
but in my simulation output, I only get 32kHz ramp signal.
I use TSMC 65nm technology in my simulation.
I attached my reference paper in this study.
Please someone expert in these things, please I need help. Thank you!
38,913
If the supply is only 1.2V, what are the MOSFET threshold voltages, Vgs(th)?
Is would seem you have very little dynamic range to work with.
AnalogKid
Joined Aug 1, 2013
12,287
The highest frequency mentioned in the paper is 700 kHz, and there is nothing to indicate or suggest that the circuit will function at any higher frequencies, let alone 100 MHz to 1 GHz.
ak
Papabravo
Joined Feb 24, 2006
22,115
ak
I've seen HF stuff on silicon before and this is definitely not what it looks like.
