I can't find the problem. 2 stages amplifier with op amps.
bertus
Joined Apr 5, 2008
23,023
There is an offset at the input of the opamp.
In your schematic it shows as -1.53 volts at the output.
This will shift the complete signal down.
Bertus
bertus
Joined Apr 5, 2008
23,023
The LM741 has an offset, this will be amplified by the second amplifier.
The LM741 has the possibility of offset compensation:
Bertus
bertus
Joined Apr 5, 2008
23,023
You have only connected a resistor.
The schematic shows a potmeter with the wiper to the - powersupply.
Bertus
bertus
Joined Apr 5, 2008
23,023
The position of the wiper will influence the offset.
When it is in the middle it will be like the potmeter is not connected.
Bertus
