I cannot understand how this circuit works
Joined Jul 21, 2018
10
What is inductor's duty
I am not sure about dual zener mabe it can be a transistor
MOD: Lightened up your image.
Ylli
Joined Nov 13, 2015
1,092
Looks to me like some kind of sweep circuit. C27 is charged through a constant current source consisting of the transistor with 3.3 volts on the base. U33 discharges C27. The op-amp, along with the FET takes the triangular input voltage and converts it to a triangular current flow through the inductors. Perhaps an analog TV vertical deflection circuit?
Dodgydave
Joined Jun 22, 2012
11,395
I think you've traced it out from a pcb, and it could be a Vertical Timebase module for an Oscilloscope , or Sawtooth generator, you might have drawn it wrong.
Joined Jul 21, 2018
10
But I think its seems a circuit that switch on and off a voltage that is generated like a protection circuit by by command of FPGA by sensing for example voltage or current.
MrAl
Joined Jun 17, 2014
13,793
So whats your idea?? (Nc means that it has no connected and placed on Pcb boad)
I did not study the circuit yet just took a quick look and my idea is that you should get a better camera :)
Ok all i see so far is that they may have wanted to save money on the inductor so they used two smaller ones in series.
It could be a power supply although i did not look up any part numbers yet.
Joined Jul 21, 2018
10
Could be a power supply?? Voltage refrence 1.2 v create a -15 volt at positive pin of op amp and it is campared to the source voltage of mosfet then the mosfet is turned on.
