Cannot for the life of me understand how to make this circuit for this lab
rmacke
Joined Sep 23, 2022
I am illiterate when it comes to drawn circuits and am struggling recreating the one in the attached diagram on my breadboard for an Electrical Lab for school, any help is appreciated.
WBahn
Joined Mar 31, 2012
32,777
What help are you looking for?
What is tripping you up?
Do you know how the internal connections on your bread board are set up?
Do you know how to use jumper wires to connect one strip of holes on your breadboard to another strip of holes?
Do you know how to identify which physical component corresponds to which symbol in the schematic?
Do you know how to identify which pin is which on those components where it matters?
Jerry-Hat-Trick
Joined Aug 31, 2022
806
Start by numbering each connection like this: 1663926857679.png
I've chosen 1 for the ground (negative rail) and 6 for the posistive rail as it's tidier to keep them apart. The emitter of the transistor is also 1 (i.e. ground) so I chose 2 and 3 for the base and collector respectively as the three legs are adjacent. Every component is then connected to their respective numbered rails.
Personally, I hate solderless breadboards, it's hard to see what's going on and connections fall out etc. Neater to place your schematic on a piece of wood and hammer small panel pins half way in wherever there is a number. Then solder in the wires and components to the panel pin tops.
Audioguru again
Joined Oct 21, 2019
6,826
I could barely see the green-yellow transistor, so I converted the schematic to black and white with increased contrast. I could not remove the grid of dots all over the schematic.
The moment that 12V is applied then the LED on the right side and probably also the transistor will burn out because nothing limits the charging current of the capacitor.
rmacke
Joined Sep 23, 2022
I'm pretty much just struggling to replicate it on my breadboard, as I can't read circuit diagrams very well
rmacke
Joined Sep 23, 2022
Start by numbering each connection like this: View attachment 276825
This is kind of helping me understand it better, but how would I go about my jumper chord placement using this schematic?
34,714
Download Fritzing and follow the tips given in post #5.
Look at some examples.
Begin by plugging in the 2N3904 transistor. Look up the pinouts for 2N3904 and follow the 1-2-3 pin identification.
Make sure all nodes #1 are connected to one supply rail.
Then connect all nodes #6 to another supply rail on the other side of the board.
Connect nodes given the same number.
Here is one example.
I wonder if the LED and transistor would survive without thermal runaway if the capacitor charges fast enough! But the circuit as drawn must be wrong. I wonder if the intended circuit was something like:
Audioguru again
Joined Oct 21, 2019
6,826
I agree LED2 needs R4 in series with it to limit its current and the capacitor was in the wrong location.
I hope the wrong circuit was not designed by the "electronics" teacher.
Exactly. Moving the components around as suggested should make LED1 come on immediately the battery is connected, then LED2 should come on after a brief delay when the current through LED1 charges the capacitor up to 0.6V to turn the transistor on.
