I blew a 1N4148 diode?!?
28,225
When a diode is applied as a shunt protection device it is ALWAYS appropriate to have a protective device such as a fuse in the supply line to avoid unlimited power delivered that will destroy the shunt diode and then all of the other polarity sensitive devices..
Thus the much safer scheme is to put the protection diode in series, so that if a reverse voltage is applied the diode will be reverse biased and not much current will flow, and damage would be prevented.
rpschultz
Joined Nov 23, 2022
851
Now that I understand this issue better, I’ll be on the lookout for it. A 1N5817 in series does appear to be the strong majority of all the guitar pedal designs I’ve looked at.
Thanks!
35,158
For power supply circuits, 1N5817 in series will reduce the supply voltage by about 0.3V (depending on current) compared with 0.7V with 1N4001 diodes.
Bordodynov
Joined May 20, 2015
3,431
There is a much better way to protect against reverse polarity - a MOS transistor.
In normal mode, the transistor is open and there is a low voltage across it. If the power is connected incorrectly, the transistor is closed.
35,158
Then it is a better choice for the series resistor. Thanks for the good advice.
Diodes are preferred in certain situations because the voltage loss does not vary as much with current (about 0.2-0.3V for 1N5817). With series resistors, the voltage loss follows Ohm’s Law.
28,225
When a SHUNT diode is used for reverse polarity protection the current limiting device should always be a fuse. When a SERIES diode is used for reverse polarity protection then a diode with a lower forward voltage drop is always the better choice..
28,225
I have used four rectifiers in bridge configuration so that it works whichever way the battery is connected.
Certainly that is a useful scheme, but without special measures that puts two diode drops in series with whatever is protected. Thus it does have a cost. But certainly it will be effective.
35,158
It can have added benefits.
Two 1N5817 diode drops is only 0.5-0.6V.
I have used 1N4001 bridge to reduce 6V battery voltage to 5V.
