I am desperate for this Inductor
Wendy
Joined Mar 24, 2008
23,859
Are you trying to wind this on that torrid? Really fine wire, a good magnifying headpiece, a little superglue now and again, and really tight loops with no spaces between them are your friend.
That or buy one of the smaller of the units we referred to earlier, and adjust the resistance with an external to match. Start with 6H, and go from there. Is your heart set on DIY?
Even on an open bobbin my 1st paragraph applies, but I am under the impression a torrid increases the apparent inductance in a small space.
Dynaman
Joined Jan 17, 2008
94
More like "DIN" do it now... I think I have to throw in the towel... I couldn't find a 6 henry with 100 ohms or less resistance that is reasonably sized unless you know of a source.
Aram:)
Wendy
Joined Mar 24, 2008
23,859
Circuit simulations aren't reality, sometimes they aren't even close. If you read the whole thread he's needing this to do a real world repair.
Wendy
Joined Mar 24, 2008
23,859
Again, this is a replacement part, not a new design. That work has been done, and if you read the thread you will see where people have simulated what the part does. Being a stereo amplifier, it is a bit important that the two sides match fairly closely.
rjenkins
Joined Nov 6, 2005
1,013
The inductor is on the slider of a 50K pot.
It's DC resistance will only have any significant effect at the limits of the pot. adjustment.
Get any 6H choke (up to 600 Ohm DC resistance) small enough to fit in the equipment and wire in place, then IF you find a problem with the control range, adjust the fixed resistors at the ends of the pot to bring the minimum resistance back to the original.
eg. If the choke resistance is 300 Ohms higher, reduce the end resistors by around 300 Ohms each.
Dynaman
Joined Jan 17, 2008
94
Wow great find on the acoustic link. I had been there but did not see that issue. I looks like his inductor is "repairable" but mine is not. Apparently this is a common problem..
Bill just to clarify.. this unit is a Bass amplifier (for Bass guitar).
I guess I could register and see if someone has an inductor to spare...
Another pass word and username.. When will it stop!
Aram
You'll never be able to rewind your existing toroid by hand with such fine wire.
In notice that the inductor in this post:
http://unofficialacousticcontrolcorpmessageboard.yuku.com/topic/2179/t/EQ-Chokes.html
is a pot core.
I have a small pot core I could send you, complete with bobbin. This bobbin could easily be wound by hand. You can put a dowel through the center hole and wedge it in, then spin the dowel with a variable speed drill.
My calculations indicate that about 1200 turns of wire (about 150 feet) would give you about 6H with less than 100 ohms DC resistance.
If you could do the winding very precisely, AWG 36 would probably do. But for a scramble wound version, you might have to use up to 40 gauge.
Theoretical DC resistances would be:
36 gauge---53 ohms
37 gauge---67 ohms
38 gauge---84 ohms
39 gauge---106 ohms
40 gauge---134 ohms
This pot core, while small, is still larger than what you've got, but I'm sure you could kluge it in.
If you're interested, post a valid email address, disguised with spaces or periods between characters.
t06afre
Joined May 11, 2009
5,934
If you get and old one, it is some risk that it will fail again after a short time. But this is actually up to your customer. If he want things to be 100% original. You get an old one. If he is happy with a new but not original part you may find a new here http://www.sowter.co.uk/eqifm.php
Tesla23
Joined May 10, 2009
560
Why not just get a 6H inductor, then add an external resistance to make it 100Ω. 2 components, much simplier.
This is not good advice. You will not achieve what you want!
Here is a plot of what happens to the effective inductance and series resistance when you place a 125Ω resistor across a 6H inductor that has 500Ω series resistance.
You can see that the resistance is around 100Ω as expected, but the inductance starts at around 0.24H and drops! So by placing a 125Ω resistor across your 6H/500Ω inductor you reduced the effective inductance to 0.24H!
If it was this easy, we could increase the Q of any inductor by simply adding a shunt resistor!
So the bottom line is that if you need this Q (and I haven't studied the circuit to see if you do) you need to lower the losses, using a shunt resistor will not work.
Wendy
Joined Mar 24, 2008
23,859
I did not say parallel, I said series, which would be identical. Black box electronics, if you have an ideal coil with a 100Ω resistor, or a coil with 100Ω in the windings, you could not tell the difference.
You're not the first to make the assumption though, I wonder why? It seems obvious to me.
t06afre
Joined May 11, 2009
5,934
Yes that is correct. If we shall be 100% so correct so will a resistor at some frequency stop acting like a ideal resistor. But for a low value resistor in the audio frequency range this is not imortant. It is futile to even disuss it.
Dynaman
Joined Jan 17, 2008
94
Gentleman:
I feel like we are at a corporate meeting. I wish i could express how much I appreciate everyone's input for the inductor from hell.. Which is what this post should have been called..
DC, I am assuming you doubt how i am using the LC77 to measure the good inductor. I measured it's twin in circuit, and it jived with schematic, and I think we all agree by now that it truly is 6H. I am not sure why you want a pic of me measuring it again... Please explain what the goal is.
Otherwise gentleman, I don't think I have the patience to build one of these by hand, especially looking at the pics on the Acoustic enthusiast site. I guess I could talk to my client via to customer and see if they would be willing to pay more. If so, would someone be willing to try? I think the easiest thing to do is make one on a standard core, then series a resistor, and bend the two in half making it radial like. I could shove that in the PCB.
Perhaps $20 bucks and maybe a coupon for a bowl of soup or a Dr. Scholls pad or something might entice someone.
Aram
Tesla23
Joined May 10, 2009
560
Ah I see the problem - my apologies. However, in the context of the thread where the main substitutes under discussion had r ≈ 500Ω and his coil had r ≈ 100Ω, your suggestion as phrased was easily misinterpreted. This exchange didn't help:
What is to be done if the 6 H inductor already has 500 ohms resistance?
You can try it, but I don't think it is usable that way (it would probably work pretty closely though). I was thinking of a lower ohmage part, I saw several during my search.
