The Electrician
- Joined Oct 9, 2007
- 2,986
Tesla23's quote of yours is from post #43, where you didn't say series and you didn't say parallel; you said "add an external resistance".I did not say parallel, I said series, which would be identical. Black box electronics, if you have an ideal coil with a 100Ω resistor, or a coil with 100Ω in the windings, you could not tell the difference.
In post #50, you said "The wire resistance is in series, not parallel though. An equivalent circuit is the 100Ω is series with an ideal inductance.". This is the only post where you used the word "series" in this connection, but you weren't talking about where to place an additional resistance, you were just pointing that the resistance of the wire making up the inductor is in series.
In post #54, again you didn't say series or parallel; you said "compensate".
In post #57, you said "I was thinking of a lower ohmage part, I saw several during my search.", but you never posted a link to a 6H inductor with less than 100 ohms, nor did anyone else. The only lower ohmage parts from your link http://4sale.sbszoo.com/inductors.htm are less than 6H, and are mechanically too large.You're not the first to make the assumption though, I wonder why? It seems obvious to me.
It's because all the inductors that people had found on the web, and had mentioned in this thread, that were 6H, had substantially more than 100 ohms, so everybody could see that adding resistance in series wouldn't reduce the effective resistance. Therefore, they figured you must be thinking that adding resistance in parallel would do the job, since that was the only other possibility other than adding in series.
All this is why people made the assumption:
