- Joined Jul 18, 2013
- 30,842
In place of the 1N4005
I was assured that the SR5200 diode would be fast enough to bleed the back emf to ground.None of those three diodes protect the MOSFET from the back emf generated when the MOSFET switches off.
A car ignition system uses a capacitor, typically 0.2uF to 0.3uF, across the points. I would suggest the same approach here. The voltage generated on the primary should be around 300V so a 400V rated MOSFET is pushing your luck.
It will protect the MOSFET from a negative drain voltage though hte intrinic diode in there will do job.I was assured that the SR5200 diode would be fast enough to bleed the back emf to ground.
Ok I will hunt around for one. Do I need any protection for my primary coil switch as I would hate to have it breakdown from a primary or secondary back emf. If only the primary is involved then a switch rated as say 600V should be fine I presume.A capacitor on the primary side will keep the voltage within bounds and allow the circuit to work. Probably the best source for that capacitor is an auto supply store. They are pretty cheap and you will get one that is intended for that function.
In an auto ignition system, the capacitor helps to protect the points so I guess it will protect the switch too.Ok I will hunt around for one. Do I need any protection for my primary coil switch as I would hate to have it breakdown from a primary or secondary back emf. If only the primary is involved then a switch rated as say 600V should be fine I presume.
___
____I wasn’t aware of any motor in the system - just a trigger system for an auto ignition coil.The graphs for pulse of the motor are examples pulse charecterization also the circuit over time effeciency
we sense the components for heat over time this is called Faradaic effieciency. The Charecterization of the circuit components is useful with regard to Faraday effeciency which is not controversial or secret in any way it is just good electro physics.
A 1200V, 40 A one? Would I still need the IN4500, or something similar, and the condenser in parallel with it to protect it?Why not use one of the IGBTs designed for ignition use?
https://www.onsemi.com/products/dis...1ZX4yfkFFQyBRVUFMSUZJRUR+UFBBUCBDQVBBQkxFfg==
Not the 1N5400.A 1200V, 40 A one? Would I still need the IN4500, or something similar, and the condenser in parallel with it to protect it?
Yes I acquired an ignition condenser of a suitable rating. So a 10V Zener should go between ground and the Gate with its Cathode towards the Gate, even with a FET? Can’t visualise it at the moment.Check saturation time for coil as it should be less than 1.5ms. Use a standard automotive condenser across either the coil or mosfet which should be rated at least 600V and 20A. Fully saturating the coil will only create substantial heating of coil and mosfet. FWIW I would use a 1KV rated SICFET instead but be very careful of the drive circuit.
Switching speed is high enough that the gate must be protected by a zener from going more than about 10V negative. That mistake cost me a mosfet and an IGBT before I dug deeply into motor drive gate protection circuits.
