HP 650 board Help with resistor
FlllP
Joined Jul 19, 2025
108
Hello people,
I was trying to do something, and I have lost(it went flying from the tweezers) the resistor that was soldered into the place marked in pic.. So I want to make sure that I found the right resistor marking so i can place another one.. I think its RI10 (page 34 in pdf) but I'm not sure... I attached the schematics of the board too.
Thank you all!
sagor
Joined Mar 10, 2019
1,056
If I read the silkscreen right, it would be RI2. The schematic shows that as a 0402 size resistor of 43 ohms, 5%.
That said, that silkscreen is hard to read and correlate exactly to the components vs that silkscreen.
I see RI10 as above the D13, which seems to be on the left side, top...
TP19 seems related to that vertical wire
FlllP
Joined Jul 19, 2025
108
Yes, you are right, I see it now! Thank you very much!
