Believe it or not, that's my Samsung Galaxy S5.... what camera did you use?
Man, have things changed in the last decade... check this out, I snapped it using an old Nokia flip-phone!Believe it or not, that's my Samsung Galaxy S5.
Yes. The colors and detail are even better than what I used to shoot with 35mm.Man, have things changed in the last decade... check this out, I snapped it using an old Nokia flip-phone!
I shot a roll of Kodachrome 25 at Mt. Rushmore with a 400mm lens and a tripod.I think only the old Kodachrome slide film rendered colors better.
I've been in Az. Every bit as hot as Fl but you aren't wet all the time.First 100 F. day scheduled here tomorrow. Spring is over.![]()
They lied to me about it being a dry heat.I've been in Az. Every bit as hot as Fl but you aren't wet all the time.
In Az, sweating actually works.
Around here, we have drenching sweats, but all they accomplish is fungus and B.O.![]()
That's why "swamp coolers" work in Arizona. Run a fan across something soggy and you have 70 degree air.The dew point is often 60 -65 degrees.
I have friends in Florida and I can't stand the humidity there..I've been in Az. Every bit as hot as Fl but you aren't wet all the time.
You should try Monterrey... just like Florida but without the beach, or the bikinis, or any of the perks... we even get hurricanes every once in a whileI have friends in Florida and I can't stand the humidity there..
Sorry, but 115° in July is still 115°. Humidity or not.I have friends in Florida and I can't stand the humidity there..
That oughta cool you off... your temper, I meanGood thing there is usually plenty of beer.
I lived in AZ and the heat was not a problem there for me but humidity kills me in FL ..Sorry, but 115° in July is still 115°. Humidity or not.
I occasionally visit Microchip for their Master's seminars. Walking around at night is like baking in an oven. And the pool water is so hot it doesn't cool you off.
Check your units. @WBahn, comments?The temperature is denser in humid air.
What does "temperature is denser" even mean?The temperature is denser in humid air.
I too have squeezed my brains trying to visualize a situation in which that concept would apply... to no avail...What does "temperature is denser" even mean?
I believe you, but I'm trying to understand why... I would've thought that water molecules (or, in most natural situations, micro-droplets) would displace air molecules (nitrogen and oxygen), therefore making humid air more dense (assuming equal temperatures in both cases)humid air is less dense than dry air.
I can understand it. He's speaking from the human side of perception. I used to play all day in a dry cold called, "snow" but I was close to death after 45 minutes of being wet in 33F air.On the other end of that spectrum, I was changing spark plugs in Phoenix at 105 degrees and it was mildly irritating. I spent 90 minutes in a junk yard in Florida at 89F last week and I was all turning red and getting confused like the beginning of heat stroke. Wetter air makes the temperature seem more effective, regardless of whether it is too hot or too cold. "The temperature is denser (to human perception) in humid air."I too have squeezed my brains trying to visualize a situation in which that concept would apply
Looking for Advice on Adding Wi-Fi and Home Assistant Support to Weather Monitoring System | Microcontrollers | 5 | |
Weatherproofing a pushbutton | General Electronics Chat | 41 | |
| S | [PCB Review Request] ESP32 and Nano Weather Station board | PCB Layout , EDA & Simulations | 2 |
