How's the weather?
Reloadron
Joined Jan 15, 2015
7,980
POW! :eek:
2 PM
Apparently a circuit breaker popped on a power pole.
I logged out without clicking my mouse. :p
First of many this summer?
Only down for an hour...not bad. :)
My computer has a UPS, but not the router. :(
I wonder what it sounds like if a circuit breaker that size pops where all the utility wires are buried.
Do they even use that kind of circuit breaker for underground utilities?
I can't tell you about underground but as to above ground we have Two 3 phase lines coming down our street. The upper is 25 KV and the lower is 13.3 KV with the 13.3 KV feeding the residential transformers. We had a run last year of squirrels getting across the 13.3 KV where it entered one transformer. I have no clue what made them suicidal at that transformer? Always the same one and once a week for a month. The fuse has a disconnect and the disconnect uses an explosive charge to make sure it opens. When that sucker would pop it was like standing forward of a 12 gauge shotgun. That was exactly what it went off like, a 12 gauge shotgun 3" high brass load! Scare the hell out of you. That transformer fed right up to our neighbors beside and across the street, we were or are on the next transformer up the road. :)
Ron
mxg2579
Joined Jun 10, 2015
15
POW! :eek:
2 PM
It was likely the fuse you heard go off, like Reloadron said. As far as the underground, the same types are fuses are in place at the point where the overhead jumps to the "pothead" and goes underground. It just isn't located directly in front of your house because normally the point where in goes underground is not nearby. Now underground padmount transformers (like the ones that feed houses in underground subdivisions) do have built in fuses and sometimes switches, in most cases. Those fuses are all located at or near the connections to the padmount transformer.
Joined Nov 30, 2010
18,224
OMG! Explosives! Call Homeland Security! Call NSA! Call CIA! Call TSA! Terror Threat Crisis!
Power Company Executives Jailed for Treason!
This has been the morning headlines. You may now resume ignoring your television.
Reloadron
Joined Jan 15, 2015
7,980
Hey, I happen to like things that go bang. Time to hand load more ammo. :)
Ron
JohnInTX
Joined Jun 26, 2012
4,787
101 in OR? Wow. I have lots of family in the Salem, McMinnville areas. Never saw that.. and 117 in the room.. Geeze
Been hot here in Dallas last few days but then, its always so this time of year. Unfair in Oregon.
Reloadron
Joined Jan 15, 2015
7,980
Today was nice in the low 80s with plenty of sunshine. Yesterday was toasty in the low 90s with high humidity. So here we sit on a big lake called Erie. My wife is considering her annual trip to Phoenix around October or November and I am thinking Aruba is nice in January. :)
Ron
Joined Nov 30, 2010
18,224
It's been raining like pouring water out of a boot for about 2 weeks. :eek:
Can't replace a rotten fence post because the water table is the surface of the ground.
Well, it goes down the the surface a few minutes after the rain stops. :oops:
Then the sod drains for...I can't tell. It hasn't stopped draining for weeks.
The rain always starts again before the gutters in the street are dry.
Oh well. Good excuse to not dig a post hole in July. :rolleyes:
Please pass the lemonade. :p
102 McMinnville, 103 now in Salem and Portland, 108 in Corvallis and Roseburg, all between two mountain ranges in the valley. Unreal heat for this part of the country.
JohnInTX
Joined Jun 26, 2012
4,787
one oh freakin' eight? Zowie. You may need to come to TX to cool off!
What's that doing to the wine in Willamette valley I wonder.
Joined Nov 30, 2010
18,224
Ten hours after the rain stopped, the back yard is still reflections in the water between blades of grass.
Apparently the sand is saturated all the way to the (nearly) impermeable layer at seven feet down.
The Weather Guessers predict this will stop after another 5 days.
Of course, in five days, the prediction might change. :(
joeyd999
Joined Jun 6, 2011
6,561
Sounds like in five days you'll be drowned.
Joined Nov 30, 2010
18,224
No. I'm too close to the ocean. The water just runs into the sea when it gets above sod level.
Meanwhile, I can't drive back to the shed to (un)load the van or I'll leave ruts up to the hubcaps. :(
Edit, 3:30 pm:
What? Dry concrete? The sun? Ow, my eyes! Haven't seen full sun for weeks!
Pretty green algae growing in the gutters as the sod continues to drain.
Another week of this and things will be back to normal, which is temperatures in the 90's and humidity to match.
Looking forward to winter, as I do every year.
ronv
Joined Nov 12, 2008
3,770
Edit, 3:30 pm:
Have you noticed any rise in sea level?
