I need to get an constant 3ma AC current through the Load of 7k to 18k range( used for impedance cardiology ) . I've tried using the standard Howland Current Pump circuit as given below with I/P voltage of 1.8Vpp or 0.636 Vrms , 68kHz , and the O/P current is only < 1.1 mA with voltage across load 0.5V .
with R1=R2=R3=R4 = 220ohm
Please say how to correct this error , or any so .
Thanks in advance , attached the multi-sim copy of circuit .
