How to write the code to display JSON data onto an OLED
  • Thread starter Deleted member 750607
  • Start date
BobaMosfet
Joined Jul 1, 2009
2,211
I started by kind of slapping together the code I had learned to display text on my little OLED, with the code that ive been using to get single readings from a website/JSON to track the longitude and latitude of the International Space Station.
Apparently this approach does not work.....:oops:
Can anyone walk me through the protocol for this type of project? not finding what im looking for online...so far...
Here's the code that I threw together, and im not surprised it doesn't work, but maybe it will help you see where im at...
Main file:
#include <Adafruit_EEPROM_I2C.h>
#include <Adafruit_FRAM_I2C.h>
#include <Adafruit_SSD1306.h>
#include <splash.h>
#include <Wire.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include "USE_ESP8266.h"
#include <TimeLib.h>
char server [] = "api.open-notify.org";
void digitalClockDisplay();
#include <splash.h>
#include <Adafruit_GrayOLED.h>
#include <gfxfont.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <SPI.h>
#include <Wire.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display;
Adafruit_SSD1306 display(OLED_RESET);
void setup ()
Serial.begin (9600);
Wire.begin ();
display.begin (0x3C);
  Serial.begin(115200);
  if (!configureNetwork()) //start the network
    Serial.println("Failed to configure the network");
    while(1)
      delay(0); //halt; ESP8266 does not like infinity loop without a delay
int ret = client.connect(server, 80);
if (ret == 1)
  Serial.println("Connected");
  client.println("GET /iss-now.json HTTP/1.0"); //the http request
  client.print("Host: "); client.println(server);
  client.println("Connection: close");
  client.println();
else
  Serial.println("Connection failed, error was: ");
  Serial.print(ret, DEC);
  while(1)
    delay(0); //halt; esp8266 does not like infinite loop without a delay
char timestampMarker[] = "\"timestamp\":";
char posMarker[] = "\"iss_position\":";
void loop ()
  if (client.available())
    String id = client.readStringUntil('"');
    if (id.equals("timestamp")) //start of timestamp
      if (client.find(':')) //a ":" follows each identifier
      unsigned long timestamp = client.parseInt();
      setTime(timestamp);
      else
        Serial.println("failed to parse timestamp.");
    if (id.equals("iss_position")) //start of position data
       while(client.peek () != '}' && client.find('"'))
        String id = client.readStringUntil ('"');
        float val = client.parseFloat ();
        client.find ('"');
        Serial.print(id + ":"); Serial.println(val, 4);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.println(id + ":"); display.println(val, 4);
  display.display();
  delay (2000);
      else
        Serial.print("Failed to parse position data.");
if (!client.connected())
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    while(1)
    delay (0); //halt, esp8266 does not like loop w/o delay
String padDigits(int digit)
  String str = String("0") + digit; //put a zero in front of digit
  return str.substring(str.length() - 2);
void digitalClockDisplay ()
  String datestr = String(year()) + "-" + padDigits(month()) +
                   "-" + padDigits(day());
  String timestr = String(hour()) + ":" + padDigits(minute()) +
                   ":" + padDigits(second());
  Serial.println(datestr + " " + timestr);
Header file:
#include <splash.h>
#include <Wire.h>
#include <WiFi.h>
WiFiClient client;
#include <SPI.h>
#include <ESP8266WiFi.h>
const char ssid[] = "Home25";
const char password[] = "6033216098";
#include <splash.h>
#include <SPI.h>
#include <Wire.h>
bool configureNetwork()
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay (1000);
    Serial.print("Waiting for connection to "); Serial.println(ssid);
    return true;
JSON is not the format you use for this. You need to convert your json into binary and move the binary onto the display in a paged format.
