The theory is Ohm's Law.@MrChips. I'll go and find more wire!Can I ask what the theory is behind this suggestion?
Well I tried to, but holding down the button for more than 4 seconds didn't do anything. However, setting the output with the trimmer shows 5.02 on the little LED display and 5.0V on my multimeter(s). (This is with a LED+resistor as load, I don't know what R as it is built in to the LED, but man is it bright!!!) I feed the buck convertor with 9V from my power supply. (Not sure how to calibrate the power supply itself, but there was a little screw slot (as in a trimpot) above the voltage and the current markings. Tried to adjust, but didn't see anything changing.Seems like the culprit is the Chinese supply itself.
For the buck converter the specs say the input voltage should be 1.5 volts higher than the output.
Did you calibrate the display on the buck converter as described?
No.Again though why would the measured voltage go down when the supply voltage indicator stays the same, under load. What am I missing here?
If I had a 9V battery and put some resistors in parallel across the terminals and connected a multimeter to the battery wouldn't I keep seeing 9V (till the battery couldn't supply enough current).? (I admit I've never tried it lol)
I just doubt that there is 8 Ohms of resistance in the wires or across the breadboard. There us something wrong that we are not being told about., not intentionally, the TS does not know either.The answer is resistance.
Conductors have resistance.
From your description of the power supply that would depend on the load. If you set the supply for 5 volts at max load the voltage would probably increase a half volt or more on a minimum load.But practically as long as my measured voltage in the circuit (with a multimeter) is 5V then I simply adjust the power supply to get that and I'm going to be okay, because that will be my voltage anywhere on the power rails
Sounds like you're on you way to solving your problems. Allow me to make one slight suggestion.Apologies for poor quality diagram, I am learning how to use tinyCAD at momen
| Thread starter | Similar threads | Forum | Replies | Date |
| B | Wire Strippers | General Electronics Chat | 20 | |
| A | USA 240V three wire L1, L2 and a Ground | Power Electronics | 13 | |
wire wrap pins | Marketplace | 10 | |
| B | How do I wire these inputs? (Guitar Amplifier) | Analog & Mixed-Signal Design | 24 | |
By-passing car amp that uses single wire speaker inputs | General Electronics Chat | 4 |
