How to wire a motor with sensors to a DPDT switch?
borgqueenx
Joined Oct 6, 2016
3
I want to purchase the following products:
https://nl.aliexpress.com/item/ONE-..._6&btsid=d52fbf7a-fcaf-478b-8fa2-a15ba52e3dd0
https://nl.aliexpress.com/item/10Pc..._6&btsid=a76cbacf-7191-4655-b929-07ec0ba95daa
I want to wire the switch to the motor so in 1 positions it goes forwards, in the second(middle) goes backwards and in the last position goes off.
Is there a way to achieve this? I am used to working with drones/UAV's, and there you have a 3-wire phases, but they are not on that little motor? Will reversing volt work? How should i wire this?
Thanks!
Alec_t
Joined Sep 17, 2013
15,159
It would be better if the 'off' position were the centre one, so that the motor isn't abruptly switched from one direction to the other (which is stressful for the motor and gears).
30,868
I don't speak Dutch but it seems there is some kind of encoder on the motor?
I see now it is just a DC motor with a hall effect sensor that has four wires, and two for the DC motor.
You don't need the sensor to run it, just the two motor wires if preferred.
