Hi i want to use shift-registers to control several 8x5 dot-matrix led-displays.
I bought a TI CD74HC164E and found a datasheet here but it doesn't work as expected.
When i put HIGH (5V) to MR (MasterReset) all my Leds light up, when putting it to LOW all turn off.
When i touch the wire connected to CP (Clock) it changes the registers at random from the induction caused, so
it's realy sensitive. When pressing the buttons connected to CP or DS1 / 2 (Serial Data) nothing happens.
Thanks for any help.
(Picture: the display is connected correctly, i did the pin allocation, the 8 Anode pins are connected to the shift-register and the Cathode of the right most column to GRD)
