How to use LM833 op amp in LTspice
Rishabh123321
Joined Mar 31, 2021
How can we use LM833 om amp in LTspice? Do i need to use any other library or is this component already present in the software (by which name )???
Papabravo
Joined Feb 24, 2006
22,113
It is in Bordodynov's library
http://bordodynov.ltwiki.org/
You want the 16 Meg library and the 25 meg examples.
The actual sub circuit is in opamp5.lib which you can find in Bordodynov's \lib folder.
To place the component:
  1. Go to Bordodynov's "ZZZ" Folder, Then "Robertugo", and select "ompamp5 ' symbol.
  2. When you go to edit the SpiceLine on the symbol to select a particular part you will see a dropdown menu. The LM883 is one of the choices.
Have fun playing with your rockets!
Audioguru again
Joined Oct 21, 2019
6,826
The LM833 is a dual audio opamp. Its datasheet shows its maximum output current and voltage losses.
Please post the circuit you want to use it in so we can show you the problems it might have.
Papabravo
Joined Feb 24, 2006
22,113
