How to use Infineon Power MOSFET models in LTspice
hoyyoth
Joined Mar 21, 2020
531
Dear Team,
I will be using infineon BSL802SN in my application.When I downloaded the spice model I obtained a .lib file which contains the spice models of many mosfets including the one I need.
I copied this file to the sub folder and in my ltspice schematic I used '.include OptiMOS2_20V_LTSpice.lib' and I changed the mosfet name to BSL802SN.
Received the below error message.
I am attaching the spice model and test circuit along with this mail.
may I know how to use the spice models when you receive files like this which contain many parts
Papabravo
Joined Feb 24, 2006
22,116
There are two ways that MOSFET symbols are used:
  1. The parameters of the device are represented by a ".model" card with a list of parameters and values.
  2. The device is represented by a ".subckt" which allows devices that are not properly represented by the standard model to be accommodated.
The error message clearly indicates that LTspice is looking for a ".model card". If I recall correctly the, the symbol needs to have the prefix attribute set to 'X' in order to link to the sub-circuit properly.
ETA: Which version of LTspice are you using?
Papabravo
Joined Feb 24, 2006
22,116
The BSL802SN device requires a symbol with 5 pins. They are as follows:
  1. drain
  2. gate
  3. source
  4. Tj - Voltage representing the junction temperature(?)
  5. Tcase - Voltage representing the case temperature(?)
I have such a symbol, but with the parts and values in your schematic the operation was not what I expected and the simulation would not run with reasonable values for V1 & V2. I've never seen a MOSFET operate exclusively from 3.3 Volts. Where did you get such a quaint notion?
eetech00
Joined Jun 8, 2013
4,724
  1. drain
  2. gate
  3. source
Hi PB
There is no internal default value for Tj, so if you use this symbol and subckt, you must set Tj to a integer value.
Use a DC voltage source and set its value, for example, to 25v to represent 25 degrees C, and then connect it to the Tj pin.
There is a different .subckt in the .lib file that can be used that doesn't simulate the case temperature, so it will use a standard 3-pin mosfet symbol. Use either BSL802SN_L0 or BSL802SN_L1. The mosfet 3-pin symbol prefix attribute will still need to be changed to X.
Papabravo
Joined Feb 24, 2006
22,116
Hi PB
I don't have much experience with these sub-circuits, but I was vaguely aware of them since they are part of the libraries from @Bordodynov
In an effort to be helpful without a deep understanding of the situation I may have bit off more than I care to chew. It is up to the interested parties to push the boundaries.
hoyyoth
Joined Mar 21, 2020
531
May I know what is the issue of using this mosfet working with 3.3V
The gate of this mosfet will be getting signal from a MCU which is working at 3.3V
The entire board will be working at 3.3V
This circuit is an IR transmitter.The LED used in this is not the one in the board.It has no spice model
Irving
Joined Jan 30, 2016
5,195
Like this:
Top pane; power dissipation, drain voltage, drain current of MOSFET
Middle: power dissipation, diode voltage, current of LED
Bottom: gate voltage and current of MOSFET
There will be one for a similar device somewhere, or create from datasheet.
Papabravo
Joined Feb 24, 2006
22,116
The first model from the library that I tried did not produce the expected results. It seems that the other models with suffixes L0 and L1 do not suffer from the same defect.
Irving
Joined Jan 30, 2016
5,195
It's not a defect, it's by design. In my example I showed the power dissipation of the MOSFET; the 5-pin version extends that idea and translates it to case and junction temperatures based on a thermal model of the package. To work the model needs to know ambient temperatures of case and junction which are represented by voltages and heat flux by current ie joules/sec = Watts. So a 25volt source connected to the case node represents an infinite heatsink at 25C. Connected via a resistor would represent a heatsink at ambient of 25C where 1ohm maybe represents 1C/W thermal resistance.
