How to turn on the LED on STM32F4 Discovery Board
35,299
I don't know from where you are copying your codes.
Open the file called stm32f4xx_gpio.h to find out what are the correct labels.
Here is the corrected code:
C:
/* Infinite loop */
         while (1)
            if (GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_0))
                        GPIO_WriteBit(GPIOD, GPIO_Pin_12, Bit_RESET);
             else
                         GPIO_WriteBit(GPIOD, GPIO_Pin_12, Bit_SET);
skyr6546
Joined Mar 22, 2019
73
C:
/* Infinite loop */
         while (1)
             else
What's is meaning of this error ?
..\src\system_stm32f4xx.c: In function 'SetSysClock':
..\src\system_stm32f4xx.c:399:5: warning: this 'while' clause does not guard... [-Wmisleading-indentation]
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
..\src\system_stm32f4xx.c:400:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'while'
C:
/* Includes */
#include "stm32f4xx.h"
#include "stm32f4_discovery.h"
int main(void)
    /* GPIOD Periph clock enable */
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
          GPIO_InitTypeDef  GPIO_InitStructure;
          /* Configure pin_A0 as input */
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
         GPIO_Init(GPIOD, &GPIO_InitStructure);
          /* Configure PD12 in output */
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
          GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
          /* Infinite loop */
                   while (1)
                       else
* Callback used by stm32f4_discovery_audio_codec.c.
* Refer to stm32f4_discovery_audio_codec.h for more info.
void EVAL_AUDIO_TransferComplete_CallBack(uint32_t pBuffer, uint32_t Size){
  /* TODO, implement your code here */
  return;
* Callback used by stm324xg_eval_audio_codec.c.
* Refer to stm324xg_eval_audio_codec.h for more info.
uint16_t EVAL_AUDIO_GetSampleCallBack(void){
  return -1;
