How to trigger a relay based on a resistance drop in a Push to Start Switch
sghioto
Joined Dec 31, 2017
8,760
Get out the voltmeter and get the readings on all pins of the LM393.
Should read as below when the switch is not pressed.
Pins....2&6 3.5 volts
Pins.... 3&5 2.27 volts
Pins.... 1&7 0.2 volts
Pin8.... 5 volts
Pin4....0 volts
Restomod
Joined Jan 17, 2026
70
I found 0.8v at pins 1&7 nothing visual undermagnification, these also connect to a 3.3k resistor with 12v on the other side...
sghioto
Joined Dec 31, 2017
8,760
That indicates pins 1 and 7 are not connected to the resistor.
Or the voltage on pins 2 and 6 is less then the voltage on pins 3 and 5.
Restomod
Joined Jan 17, 2026
70
I’ll move the pin 1,7 to 3.3 Kohm connection to see if there is a change, however the other pins measured as defined above
Restomod
Joined Jan 17, 2026
70
Found the problem ground came loose at pin 4 after flipping
relay latches - not seeing 12volts, it flutters .00+/-
I'm using the relay above A1 A2, expecting 12v, thoughts?
Restomod
Joined Jan 17, 2026
70
The relay is labeled NO
when 12v is on - it is powered.
And when the board action closes latches the relay it goes to an open, 0 volt state
I tried reversing NO and COM same result
So this is opposite expected, this relay doesn’t have the NC option terminal
Thoughts on a solution?
Get the relay that has NO NC ?
sghioto
Joined Dec 31, 2017
8,760
Not sure the problem here.
The circuit is powered continuously and when the relay activates it sends 12 volts to the master control.
A master ON/OFF switch Sw2 can be added if needed.
Restomod
Joined Jan 17, 2026
70
An master ON/OFF switch Sw2 can be added if needed.
I agree the circuit is working as intended
the relay is “labeled” as a NO relay
it’s sending 12volts with switch open
and when switch closed 0-zero volts
since it is as pictured a NO only relay to me it’s backwards or Amazon quality defect
