I think this should be asked in the Radio & communication forum or general electronics chat, isn't it?
RF tx/rx-433What module are you using?
The antenna could be a monopole, length 17cm.
sir i have posted the same in Radio and CommunicationI doubt this is the right place for this question!! General electronics chat and radio/communication forum may be very helpful...
http://forum.allaboutcircuits.com/showthread.php?p=454015#post454015Post the complete circuit diagram of what you have built.
thankshello,
rf and a breadboard are a bad combination.
The capacitance of the connection strips inside the breadboard will destroy the rf performance.
In general, yes.Hello,
RF and a breadboard are a bad combination.
In general, yes.
On the other hand, all RF circuitry is already on the transmitter module. The breadboard shouln't be the problem, unless something is wired the wrong way.
@mkbutan
Looking at your transmitter circuit from post #14, did you check the voltage levels at the digital (!) inputs of the encoder?
What TX module is this again? Is there no enable pin or similar?
What exactly is the circuit not doing?
