Is there any tested tutorial on how to make a diamond tester? All I can find are block diagrams.
Basically I put emphasize on differentiating between diamond and moissanite because this is where the biggest confusion arises.A bit more information might be useful. What is it about a diamond you are trying to test? To distinguish between a diamond and glass, quartz, or cubic zirconia? To determine the grade of a diamond? Or are you talking about a tester that is made from a diamond.
We are not mind readers.
Rather than have us repeat your unsuccessful efforts, please post the block diagram.
ak
Wouldn't a simple Ohmmeter test distinguish between them?Pure diamond conduct no electricity but it is heat conductive. Moissanite is vice versa.
| Thread starter | Similar threads | Forum | Replies | Date |
| F | simple tester | Test & Measurement | 10 | |
| F | simple tester | Analog & Mixed-Signal Design | 2 | |
LED TV backlight tester - Why two DIACs ? | General Electronics Chat | 38 | |
Trying to make a moped ignition coil tester | General Electronics Chat | 51 | |
Do you believe this thing? Amazing tester ? ? ? | General Electronics Chat | 61 |
