LED TV backlight tester - Why two DIACs ?
ranatungawk
Joined Oct 30, 2008
226
This is a DIY LED TV backlight tester. I found this on the internet. Could you please tell me the purpose of the two serially connected DIACs placed between the + and − terminals of the bridge rectifier?
Papabravo
Joined Feb 24, 2006
22,116
It is hard to tell what the internal connections might be, but it is possible that the internal connections might be different than the picture. If you search for the datasheet, it comes back as a bridge rectifier. I rest my case.
Alec_t
Joined Sep 17, 2013
15,167
If one diac drops 14V (as per Eric's sim), then two in series will effectively create a 28V pulser in that post #1 circuit.
ranatungawk
Joined Oct 30, 2008
226
This is not something internal. these two have been connected externally
hi rana,
This is what LTSpice shows.
E
Thanks for the reply. but your diagram is wrong. pls see the pic.
AnalogKid
Joined Aug 1, 2013
12,296
The DB3 DIAC has a breakdown rating of 28V to 36 V. The two diodes in series form a bidirectional 64 V -ish clamp across the rectified DC output.
The 120K resistors limit the shunt current.
file:///C:/Users/User/Downloads/db3.pdf
ak
ranatungawk
Joined Oct 30, 2008
226
ak
Thanks for the explanation.
With this setup, once the voltage reaches 64V, + and − will be shorted, and the DIACs may heat up, correct? and can I connect an electrolytic capacitor (10u, 400V) between + and - ?
ericgibbs
Joined Jan 29, 2010
21,643
hi ranatung,
Sorry about the previous circuit error, this is a corrected version.
R3 is for the simulator operation, also the simulator uses the Peak voltage of the 230Vrms
What are the details of the LED types being tested??
E
ericgibbs
Joined Jan 29, 2010
21,643
hi ranatung,
This shows the result for 3 Medium power LEDs in Series.
E
@ranatungawk
Note: I assume you are aware of the risks when using this test device, as there is no mains isolation. Using an isolation transformer is always the best option to ensure your safety.
AnalogKid
Joined Aug 1, 2013
12,296
Not exactly shorted, but a low impedance with a minimum DC voltage across them. Because these are DIACs, there is no (or very little) current conducted through them until the voltage across them is greater than their trigger voltage.
DIAC power dissipation is limited by the two 120K resistors. Worst case (dead short) current is 960 uA (0.98 mA) RMS. If there is, say, 10 V across each DIAC when conducting, that is around 9 mW per DIAC.
Cap across the output - yes.
ak
