how to stop alternating current flow in a circuit without mechanically disconnecting wire/conductor
WBahn
Joined Mar 31, 2012
33,187
Need some additional information. How much voltage/current are we talking about? Is the circuit inductive? What will control the circuit?
jpanhalt
Joined Jan 18, 2008
11,087
Have you heard of solid state relays? Some will interrupt AC. Then, all you need is the signal to initiate an on/off action.
Reloadron
Joined Jan 15, 2015
7,946
You can mechanically disconnect using a switch or relay contacts, if that is not what you want you can electronically disconnect using as mentioned a SSR (Solid State Relay). Since you mentioned:
without mechanically disconnecting wire/conductor?
You aren't saying much there? Also a "home appliance" can be a large load like an electric drier or a light load like a small electric knife sharpener. You really need to be more specific.
Ron
sou30719
Joined Sep 9, 2019
Ron
Hi, Thanks for your time. I don't want a mechanical switch ...but a continuous conductor.
Home appliance can be anything from drier to small appliance....can be wide variation.
MaxHeadRoom
Joined Jul 18, 2013
30,808
+1 for Triac/Thyristor, it can be turned on using one resistor and an ordinary home light switch.
I refer to a coil/contacts device as electro-mechanical.;)
Max.
WBahn
Joined Mar 31, 2012
33,187
I'm not aware of any practical solution that would interrupt the AC current in a continuous conductor.
MaxHeadRoom
Joined Jul 18, 2013
30,808
I have used a triac in with a motor centrifugal start switch, the centrifugal switch just triggered the triac and avoided the arcing premature failure of the switch itself.
Max.
Reloadron
Joined Jan 15, 2015
7,946
Then I am with the others who have suggested a Triode AC Switch” or Triac. Just make sure the Triac you choose can handle your load and you will still need a method to gate the triac. Electronic switching is normally designed around an intended application so the answer to your question is generic.
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,808
Switching any Triac device comes down to the method you require to control it automatic or manual?
If automatic, what process decides this?
Max.
